receive fluent received a fatal signal (Segmentation fault). |
March 6, 2015, 14:50 |
Michigan
hi,
I have a UDF as, #include "udf.h" #include "mem.h" DEFINE_PROPERTY(viscosity3, c, t) { real tt,time; real Z; real strain_rate_nu; real yield_stress; real vis; tt=C_T(c,t); strain_rate_nu=C_STRAIN_RATE_MAG(c,t); Z=strain_rate_nu*1.0e-15*exp(196835.0/8.314/tt); yield_stress = 188.68*log(pow(Z/6.26,1.0/5.06)+pow(pow(Z/6.26,2.0/5.06)+1.0,0.5)); vis=yield_stress*1e6/3.0/strain_rate_nu; return vis; } but every time when I try to use this, the fluent received a fatal signal (Segmentation fault). shows, even when I try to run it without UDF and then put it back, the errors shows up, someone can help me ~~~~~~ |
March 10, 2015, 05:48 |
Paritosh Vasava
Rep Power: 22 |
The only reason I can think of is that you have not activated the energy equation. Because of that the simulation can not access the temperature data via C_T(c,t).
March 10, 2015, 08:21 |
Rep Power: 26 |
Are you sure this equation has no typo's?
If I try a temperature of 300 Kelvin, then exp(196835.0/8.314/tt) is equal to 1.8e34. This number may be too big to hold, if you are running single precision. If this equation is really what you want, then you might use some numerical tricks to make it numerically better: Code:
Z=exp(196835.0/8.314/tt+log(strain_rate_nu*1.0e-15); |
Fluent15: received a fatal signal (Segmentation fault) | lcg44 | FLUENT | 4 | August 29, 2016 12:19 |
Error: received a fatal signal (Segmentation fault). | Revist | Fluent UDF and Scheme Programming | 1 | December 12, 2014 13:18 |
FLUENT received fatal signal (ACCESS_VIOLATION) | LemonPeng | FLUENT | 5 | September 3, 2013 06:42 |
FLUENT received fatal signal (ACCESS_VIOLATION) | jwt | FLUENT | 2 | July 1, 2010 08:35 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
