December 30, 2020, 13:42 |
apply pre-stress in simple membrane
julia
Rep Power: 5 |
Hi. I am doing a 2way fsi simulation in ansys fluent and transient structural about 2.5D membrane airfoil. z coordinate has only 1 element, and deflections in x and y axis just important. the picture attached.
the leading edge , lower part of middle of airfoil and small part of trailing edge are fixed and between them there is a flexible membrane in top (0.5mm thickness, 1500kg/m3 density and 80Mpa young module ). i set zero displacement in z coordinate for both thin symmetry plane of my geometry in structural and then define fluid solid interface. i used remeshing and smoothing for dynamic mesh. but my problem: this membrane must have pre-strees in chord wise (300KPa) . how can i apply this prestress? |
simpleFoam tutorial PitzDaily using Reynolds stress tensor (LRR RASModel) | dlahaye | OpenFOAM Running, Solving & CFD | 24 | August 4, 2023 14:29 |
how to apply initial stress state in ansys | novianty | ANSYS | 0 | September 2, 2017 00:14 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
SIMPLE algorithm in 3D cylindrical coordinates | zouchu | Main CFD Forum | 1 | January 20, 2014 17:02 |
Apply Multigrid method to SIMPLE Algorithm | yang | Main CFD Forum | 1 | February 25, 2006 11:28 |
