UDF for a time varying temperature boundary conditions
Old   October 22, 2015, 04:20
Default UDF for a time varying temperature boundary conditions
giuseppe lombardo
peppelmb is on a distinguished road
I'm VERY new to Fluent and I'm attempting to write a UDF that will make the temperature at a wall a function of time. I've never programmed in C before either so I'm having some trouble getting the correct UDF.
I'm working on an aluminum casting made from a sand casting process. I decided to use a specimen, as a representative part of my process, which has been reduced in geometry to its initial gauge length. As a result I have, as can be seen from the screenshot below, a cylindrical aluminum piece surrounded by a cast iron chill and the sand mould. What I want to figure out is how to do the simulation, starting by put the boundary conditions, passing through the mesh setting and finishing up with the computational setup.
I need to put three different temperature profiles on three boundary conditions as below:
1. between the metal and the chill
2. between the metal and the sand mold
3. between the chill and the mold (three highlighted surfaces)
How can I define a correct code for these boundaries? Thanks in advance!
peppelmb is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Boundary conditions for time varying crosswind krembil FLUENT 1 April 10, 2015 04:44
UDF for a time varying temperature majidmng Fluent UDF and Scheme Programming 0 November 21, 2013 01:38
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
