Divergence:Temp with heat flux boundary condition
Old   April 26, 2015, 04:18
Default Divergence:Temp with heat flux boundary condition
ASUTOSH PADHY
asutoshpadhy is on a distinguished road
I am trying to learn the basics of convective+radiative heat transfer to surroundings. For this I modeled a basic 10 mm thick flat plate and positioned it with its thickness facing the flow.
I created the air mesh around it using Boolean operation with a enclosure size of 200mm(uniform). Then I assigned the front end(enclosure) as inlet, rear as outlet and the sides of the plate as heat flux by named selections.
Then I proceeded as usual with pressure based, steady state, absolute velocity. For Models, I turned on Energy, K-E realizable, Radiation P1. As for Air coefficients I fed 0.001 as absorption coefficient, 0 as scattering and emissivity as 1.
Boundary condtions -
Velocity inlet - 17m/s
Pressure outlet - 0 Pa
Heat flux - 3.2 e6 W/m^2
Rest all proceeded with default standard and Hybrid initialization. AMG Solver detects Divergence Temperature within two iterations. How do I overcome it?
P.S: I'm a novice. Thanks in advance.
asutoshpadhy is offline   Reply With Quote
divergence temp, heat flux fluent udf
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Problem with Turbulent Heat Flux Temperature boundary condition Manuel CFD OpenFOAM Running, Solving & CFD 11 March 17, 2016 15:12
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 20:11
constant heat flux boundary condition manoj_1 Phoenics 0 June 27, 2010 13:07
