May 12, 2015, 18:53 |
Increasing residuals!!
Martin
Rep Power: 11 |
I simulated a turbulence flow of an elliptical pipe which converged and I got reasonable results. Then I did the same simulation but this time I changed the orientation of the major and minor axis. Now my residuals are positively increasing and the flow is dissapering. I don't now why it does like this. Does anyone have an idea? Also after some iterations, the mesh of the inlet disappears as well Last edited by Martin1; May 12, 2015 at 19:41. Reason: additional information |
May 12, 2015, 20:10 |
vlg
Rep Power: 17 |
Hi!
And how did you change your axes? Did you construct the mesh from the beginning by hand - maybe, some mesh issues. Do you use external forces (gravitation)? Have you started your calculation from previous results (exchanging the mesh) or created the case file from scratch? |
May 12, 2015, 20:13 |
#3 | |
Martin
Rep Power: 11 |
May 12, 2015, 21:11 |
Martin
Rep Power: 11 |
Oh sorry, I misunderstood your question. I changed the axis in the design modeler, I just changed the diameters. Did not construct the mesh or geometry again.
Residuals decreasing in the beginning and then increasing --MRFSimpleFoam | kingmaker | OpenFOAM Running, Solving & CFD | 0 | February 10, 2014 09:22 |
motorBike Residuals for SST k-omega... and mine | JR22 | OpenFOAM Running, Solving & CFD | 6 | August 1, 2013 09:08 |
increasing initial residuals of U.x and h when shock wave reachs the wall | immortality | OpenFOAM | 0 | June 26, 2013 12:55 |
judging convergence through residuals | MachZero | Main CFD Forum | 7 | December 25, 2012 12:18 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
