DO/Energy coupling with the Composition PDF method |
May 24, 2015, 22:35 |
Luleå tekniska universitet
Rep Power: 11 |
Hello all,
I am trying to add the radiation effect using the discrete ordinates model using the composition PDF method in FLUENT. When I enabled the DO/Energy coupling, I got an error: "The DO/Energy coupling option should not be used when the composition PDF transport model is enabled". We enabled it to accelerate the convergence of the finite volume scheme for radiative heat transfer and can be used with the gray or non-gray radiation model. My question is why we can't enabled that option? Does this effect my results? Thanks in advance. Regards: MAC |
composition pdf method, discrete ordinates method, do/energy coupling |
New Chemical and Composition PDF in 3D? | abiss | FLUENT | 0 | September 7, 2009 04:55 |
help of Monte Carlo PDF method | Atsushi Yamada | Main CFD Forum | 12 | April 16, 2001 02:12 |
pdf method in turbulent Combusttion | Hidouri ammar | Main CFD Forum | 1 | August 21, 2000 10:47 |
pdf method in turbulent Combusttion | Hidouri ammar | Main CFD Forum | 0 | August 19, 2000 05:19 |
PDF Method for turbulent flows | Bipin Lokhande | Main CFD Forum | 1 | November 8, 1998 13:07 |
