mass flow rate in DPM steady tracking
Like Tree2Likes
  • 2 Post By pakk
Old   June 1, 2015, 09:26
Default mass flow rate in DPM steady tracking
Roule is on a distinguished road
hi all
i want to inject a single particle (mass = 0.001 kg) in a flow, and track the particle using steady DPM.
but in the 'Set Injection Properties' dialog box, it asks for the flow rate (kg/sec)..so how do i decide this flow rate...
should it be
(1) just the mass of the 1 particle, like 0.001 kg/s
or
(2) particle area * density * flow velocity at the injection point
if option (1) then the problem is
that i want to inject only 1 particle, so using 0.001 kg/s will mean something else..isn't it?
and if option (2) then
how do I know the velocity at the injection point?
do i have to run the simulation without DPM first, get the flow velocity at injection point, and then use it to calculate the mass flow rate.
i am just a bit confused about this flow rate thing..
if anyone has any idea, please share...
thanks a lot..
Roule is offline   Reply With Quote
Old   June 1, 2015, 09:58
pakk will become famous soon enough
That flow rate is relevant for postprocessing of your results. If you have two sources of particles, and one source gives 0.1 kg/s and the other 0.3 kg/s, you put those numbers and Fluent will do the relevant postprocessing, while it (at minimum) only needs to calculate two trajectories. It does not influence the trajectory calculation in any way, at least not when the DPM and flow solution are uncoupled.
In your case, you don't need this kind of postprocessing, so you can put any number you want. Make it 1 kg/s, and you are done.
pakk is offline   Reply With Quote
Old   June 1, 2015, 10:14
hi thanks for such a quick reply
actually i have enabled "interaction with the continuous phase" in the DPM dialog box. so will the flow rate value affect the trajectory?
so if i use 1 kg/s, then will it inject just 1 particle or 1 kg/0.001 kg = 1000 particles...how is fluent knowing how many particles to inject..i just want to inject 1 particle..
so what does that flow rate actually mean:
is it the rate at which the particle is moving in the flow
or
is it the rate at which the particle is injected into the flow
sorry for asking so many questions,
i just want to know it properly.
thanks so much for ur quick reply
Old   June 1, 2015, 10:27
I believe that in that means that the particle will influence the flow, and the flow will influence the particle. If you disable it, the flow will still influence the particle, but not the other way around. Disabling it will make your simulation much, much faster. So only enable it when you are sure it will influence the flow. If you inject a single particle of 1 gram, it will not influence the flow significantly, so disable it.
If you select 1 kg/s in a steady simulation, Fluent will still inject 1 particle. Like I said, the "1 kg/s" is just a label.
or
It means neither. It means the flow rate that your calculation particle represents. If you put "1 kg/s", and your particle has a mass of 1 gram, then Fluent knows: "If I ever have to do any postprocessing from this trajectory, I can imagine that 1000 particles follow this trajectory every second."
But, as I said, you are not going to do that kind of postprocessing. So in your case it is just a label that will not be used for anything. You can enter your age, your phone number of your favourite Reynolds number, it does not matter.
soheil_r7 and shahab1994 like this.
Old   June 1, 2015, 10:44
Default thanks a lot :)
Ya, u r correct..my particle is too small to affect the flow...i will just disable it to speed up the iterations..thanks
i see, thanks for clarifying again.
You can enter ..... your phone number of your favourite Reynolds number,
okay, funny, i will ask my fav reynolds number abt her phone number
and thanks so much for helping me out, now i am clear about the problem i had..thanks so much...
and can i ask one more favor from u,
since u have already been so helpful.....i asked another question in the forum yesterday but didnt get any proper reply, it is also about/related to DPM only..
if u dont mind, can u see that question too, and give some suggestions...i feel u may know what to do..here is the link to the question:
http://www.cfd-online.com/Forums/flu...me-cavity.html
sorry for asking so many questions...
thanks so much again
discrete phase model, dpm fluent, injection model, mass flow rate, steady state
mass flow rate not conserved in turbomachine, interface defined wrong? wildli FLUENT 3 September 15, 2022 12:19
DPM injection mass flow rate kingpots ANSYS 0 November 22, 2012 11:12
Mass flow rate of the DPM mass sourse ?? Rhinocao FLUENT 3 January 21, 2011 12:10
Mass Flow Rate student87 CFX 4 January 2, 2010 04:45
DPM outlet mass flow rate vk FLUENT 1 April 18, 2008 14:13
