June 25, 2015, 03:21 |
Issue regarding Drag Coefficient
Manish Kumar Nayak
Rep Power: 11 |
Hello, I am doing CFD for the first time, so my doubt might be trivial.
I am doing an external flow calculation over an Airship, keeping the domain as Pressure Far-Field. I have named parts in my geometry, named as Gondola, Hull and Fin (just mentioning in case it helps). I select these parts in the solution monitor and enable the plotting of cd values. My requirement, I want to vary the angles of the gondola front and back, and get an optimum minimum drag and flow separation situation. Doubt 1. Since I need the forces in x direction, I print the forces after calculations are done and I get total forces, pressure and viscous on each part along with their respective Coefficients and check the x part. In the few different iterations I have done, the gondola viscous coefficient comes out between 5-10 and the total cd that is output in my folder as a result of my solution monitor initialisation comes between 1900-2100. I find both these values unreasonable, are these really drag coefficients? Am I doing something wrong? Doubt 2 Is it okay if I just check the cd value, or do I need to see flow separation too. I personally don't think it is necessary because cd values are a result of flow separation. So higher separation should naturally result in higher cd values. Please hepl me know how to proceed in the correct direction. |
cd values, post processing |
Drag Coefficient for Ellipse Form (2D) | Ketut Utama | Main CFD Forum | 8 | December 11, 2014 12:03 |
problem with saving drag coefficient | colopolo | FLUENT | 5 | April 12, 2013 11:59 |
Post Processing Drag Coefficient | squanto773 | OpenFOAM Post-Processing | 1 | March 7, 2012 10:43 |
Plot drag coefficient against Y(distance) | edwin | FLUENT | 0 | February 4, 2008 10:41 |
Energy dissipation and Drag coefficient | Freeman | Main CFD Forum | 10 | January 27, 2006 08:42 |
