Error: Divergence detected in AMG solver: x-momentum |
June 29, 2015, 10:25 |
Gustavo
Rep Power: 10 |
I´m trying to simulate the gas (O2 + N2) flow inside a low pressure chamber. In this moment I´m not interested in reactions. I´m using steady state, laminar model (Low Pressure boundary slip), activated energy equation and species Transport (inlet Diffusion, Diffusion energy source, Thermal Diffusion enabled). Operating conditions - 1Pa inlet (mass-flow-rate) = 4.26e-6 outlet (pressure-outlet) = 0Pa When I start Simulation the message error appears "Error: Divergence detected in AMG solver: x-momentum" and I´m not able to solve it. I tried to reduce the Relaxation factors... but didn´t worked. Anyone has a hint? thanks in advance |
June 29, 2015, 14:06 |
Jim
Rep Power: 11 |
try the following:
- don't use mass flow; stick to velcity inlet and pressure outlet. do a back-of-the-envelope calc to find velocity from continuity. - don't mess with the URFs justnow; stick to the defualt settings. - don't start with mixtures; start with the defualt air. keep going more and more simple until it works. also, could be an issue with the mesh. have you named the inlet & outlets etc ? |
June 29, 2015, 15:06 |
Gustavo
Rep Power: 10 |
Thank you so much for your suggestions. I will try it and let you know. Regarding your questionar I named The outlet and outlet. Should I named walls too?
How can I find The velocity from The continuou equation using mass flow rate? The Knudsen number is 0,038 Thanks |
August 7, 2015, 10:20 |
Jim
Rep Power: 11 |
Hi gustavo,
sorry, I shouldn't have called it a "continuity equation", the term is ambiguous in this context. I meant: Q=rho*u*CSA mass fr = density * velocity * cross sectional area for flow. and rearrange for velocity. |
divergence amg solver |
divergence detected in AMG solver: momentum | sudhakar | FLUENT | 41 | January 23, 2024 03:56 |
Error: Divergence detected in AMG solver: pressure correction | wanna88 | FLUENT | 19 | April 6, 2016 02:57 |
AMG solver divergence; | Mike | FLUENT | 17 | December 14, 2015 13:01 |
Divergence detected in AMG solver: pressure correction | xinquanzhoucn | FLUENT | 5 | July 21, 2014 04:49 |
Error: Divergence detected in AMG solver: x-momentum/ epsilon/ temperature | bubuchacha | FLUENT | 6 | February 26, 2013 03:30 |
