June 29, 2015, 08:07 |
Dpm
antonio
Rep Power: 10 |
hi friends
when i want set DPM settings, i must enter start time and stop time for injector, my problem is steady. so, what i set in start time and step time? thanks |
June 29, 2015, 09:08 |
Ethan Doan
Rep Power: 13 |
Unclick the "unsteady particle tracking" box in the DPM window then this start and stop time will not show up in your injection tab
June 30, 2015, 08:05 |
antonio
Rep Power: 10 |
thanks Ethan Doan for your answer, but in help writed its better chose "unsteady particle trackind", so do u underestand what i do now?
thanks |
June 30, 2015, 09:40 |
Ethan Doan
Rep Power: 13 |
In the DPM tab you should have your particle time step size and number of time steps. The product of these two is the total time the injection will be calculated if you want a continous injection you can set your start time at 0 and the end time at this number. I think that will work but I have no used this unsteady particle tracking with a steady state flow myself. Best of luck!
June 30, 2015, 14:54 |
antonio
Rep Power: 10 |
thanks dear Ethan Doan. do u simulate combustion?
i have some question about PDF and flamlet? best regareds: |
Dem v.s dpm? | Amir1 | Main CFD Forum | 1 | November 3, 2019 09:52 |
DPM mass flow | kingpots | FLUENT | 0 | November 29, 2012 22:20 |
Dpm injection mass flow rate | diamondx | FLUENT | 0 | November 22, 2012 13:04 |
how to use DPM from DPM file unsteady? | Cloud | FLUENT | 0 | November 10, 2011 04:25 |
DPM - do the particles affect the liquid? | Nikhil Dani | FLUENT | 0 | January 1, 2009 11:58 |
