July 24, 2015, 03:48 |
Reference values in FLUENT
Hi everybody,
I have a doubt about the "reference values" in FLUENT. I want to simulate a H-rotor DARRIEUS, with these characteristics : . H=0.4m . R=0.3m . S=2*R*H=0.24m˛ What are the values for "Depth" and for "Length" in FLUENT ?? I thought that "Depth"=H, and "Length"=R... BUT I've seen that if I double the value of "Depth" in the reference values, the moment coefficient (Cm) is also double; however, Cm=C/(0.5*ro*S*R*Uinf˛), isn't it ? So with the same values of "length" and "Area", Cm would be the same, no ? Thank you very much for your explanations ! |
July 24, 2015, 10:30 |
Lucky
Rep Power: 66 |
The depth property is only for 2D simulations for scaling of the cell volumes in the "depth" direction.
In 3D you would be correct (although there would be no depth reference). However, in 2D you cannot increase the depth while keeping the physical area constant (since the force is the product of the pressure and physical area). That is, when you double the depth you double the area over which the pressures act and hence the force is doubled. |
July 28, 2015, 11:53 |
Thank you very much for your answer LuckyTran
cfd, darrieus, depth, fluent, reference values |
can not complie fluentDataToFoam in OF2.1.1 | hewei | OpenFOAM Pre-Processing | 20 | September 8, 2018 09:19 |
Reference values and operating conditions | saisanthoshm88 | FLUENT | 5 | November 26, 2014 11:33 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
