Boundary conditions for flow in nozzle
Old   July 26, 2015, 12:46
Default Boundary conditions for flow in nozzle
kgevers
kgevers is on a distinguished road
Hello all!
I need to model the flow of air (considered as a compressible ideal gas) passing through a nozzle. The simulation is in 2D.
I use a density based solver, steady state flow, k-omega SST model, implicit method, start with first order upwind scheme.
I know my total pressure inlet as well as the mass flow rate.
Now, my question is: what should I set for the boundary conditions? Does it depend on the flow regime? It can be either subsonic, transonic or supersonic depending on my total pressure inlet.
-> If all the flow is subsonic, I impose inlet and outlet pressure (outlet is atmospheric pressure).
-> If the flow is transonic, again inlet and outlet pressure (atmospheric because flow is subsonic) should give a correct result. But a first question arises here: when is the flow transonic and when is is supersonic? I can calculate it using isentropic flow equations but this is an approximation. Is it the way to do it?
-> If the flow is completely supersonic, what should I do? Can I use inlet pressure and outlet pressure with target mass flow rate? In the user-guide, it is written that "The pressure outlet will not achieve the target mass flow rate if the flow becomes choked". Which is the case isn't it?
Can I use the same boundary conditions regardless of the flow regime? Pressure inlet and pressure outlet with target mass flow rate?
Thanks in advance for your help
kgevers is offline   Reply With Quote
boundaries condition, nozzle, supersonic, target-mass-flow-rate
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Radiation interface hinca CFX 15 January 26, 2014 17:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
