July 30, 2015, 01:40 |
chemical reaction
Rep Power: 11 |
Hello together,
is there any way to do chemical reactions without knowing the reactionmechanism? Just to see where the fluid flows and where the products after the reaction occur? Thanks for your advices! Sara |
July 30, 2015, 02:40 |
Cees Haringa
If you use the volumetric reaction model, you don't need to know the mechanism. Just specify a reaction A -> B. By default, FLUENT uses a power-law Arrhenius model, so you need to put in: a) stoichiometry (do make sure the molar mass of reactants and products matches b) power-law exponents (for a first order reaction, set it to 1 for reactant A) c) pre-exponential factor and activation energy (this determines the rate) Alternatively, you can supply other kinetics than power law via a UDF. But you never need to know the exact mechanism. |
July 30, 2015, 02:47 |
Rep Power: 11 |
Thanks for your answer
Is it possible to use this way doing surface reactions ? |
July 30, 2015, 04:02 |
Gustavo
Rep Power: 10 |
Hi Sara,
are you working with atmospheric pressure or low pressure? |
July 30, 2015, 04:35 |
Rep Power: 11 |
most probably with atmospheric pressure. Right now it is very confusing because i donīt know all the conditions yet. I know that i have a chemical reaction between a gas and a solid. And they react on the surface to a gas and a solid. Important is that i simulate how the gas flows around the solid and how the gas formed by reaction on the surface flows away from the solid. It is so difficult for me! is it even possible to do?
July 30, 2015, 04:44 |
Gustavo
Rep Power: 10 |
Iīm also beginner... but I i think it is possible. But you will have different behaviours of the flow depending on the operating pressure.
July 30, 2015, 04:47 |
Rep Power: 11 |
I try it first with atmospheric pressure. I wondered if thereīs a way to do it like take a gas through the inlet and to say thereīs a gas flowing from the surface. Mavbe with source term UDF or something. But i donīt know how. Or is it a stupid idea?
July 30, 2015, 04:50 |
Gustavo
Rep Power: 10 |
I never worked with UDF, but how is your chamber geometry. Because if you have your inlet and outlet... the gas will flow in this direction... then with the streamlines or maybe vector plot you can see how the gas will flow in the surface..
July 30, 2015, 05:02 |
#9 |
Rep Power: 11 |
I made a little sketch. I hope it can help.
July 30, 2015, 05:10 |
#10 |
Gustavo
Rep Power: 10 |
So, I have not yet worked with reactions. But I would suggest in a first step to simulate just the flow in order to understand this behaviour and then start with the reactions. What do you think? Because maybe in this step you can figure out that your inlet is not in the best place or certify that it is ok.
July 30, 2015, 05:17 |
#11 |
Rep Power: 11 |
Yes, you are right! I go first without the chemical reaction! Thank you!
But then i have to find a way including the reaction but i think there is too much i donīt know about the chemistry, because itīs a new chemical process which we develop here at university. So i thought maybe doing it without real material properties but i donīt know if that brings good results. I appreciate every advice! |
Chemical reaction using Eddy Dissipation Model in FLUENT | hyperflow | FLUENT | 5 | June 11, 2012 04:54 |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 16:55 |
CFX5.7 - chemical reaction problem... | H.L. | CFX | 4 | March 25, 2009 10:33 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
chemical reaction - howto | Dan Sorensen | Siemens | 1 | February 21, 2000 09:20 |
