Boundary conditions repeating every single cycle (periodic?) |
July 30, 2015, 13:41 |
Rep Power: 12 |
Hi!
I've encountered a little problem while modelling heat transfer through the piston of combustion engine. One of the BC is supposed to be defined by heat transfer coefficient and free stream temperature. Both coefficient and temperature are crank angle dependant. Data which I own is in the form of pairs [crank angle : coefficient] and [crank angle : temperature] e.g. [0 : 320] [1 : 326] . [720 : 458] and they repeat every cycle (720 deegrees). My question is: how can I input those BC? Should I calculate mean cycle coefficient and temperature and set them as a constant? I thought of periodic boundary conditions, but it looks like they don't work that way. How would You do that? Last edited by vExus; August 18, 2015 at 11:04. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
several fields modified by single boundary condition | schröder | OpenFOAM Programming & Development | 3 | April 21, 2015 05:09 |
SU2_MSH: Periodic boundary conditions bug | Zef | SU2 | 1 | February 18, 2015 13:28 |
Problem with Periodic Boundary Conditions Help!!! | otsigun | FLUENT | 0 | July 11, 2013 03:20 |
periodic boundary conditions fro pressure | Salem | Main CFD Forum | 21 | April 10, 2013 00:44 |
