August 10, 2015, 14:20 |
Turbulence boundary conditions
Rep Power: 10 |
I am trying to simulate an air flow in a pipe, steady state, k-e turbulence model. Let's just say that the mesh is appropriate with the appropriate y+ for the wall functions.
At the inlet, I specified a turbulent intensity of 10% and hydraulic diameter of 0.3556m (14" pipe). Though I know that the T.I. might be a little on the high side, I would like to know if the calculation can sort of self-correct this T.I. to an accurate value down the pipe? In fact, I think I have an answer for my own question, that is, my results shows that the T.I. drops to about 0.04-0.05 (4-5%) down the pipeline. However, here comes the puzzling portion: the T.I. at the inlet (and a little bit downstream) is 0.56 (56%)? This is far more than what I specified (10%). Why did the turbulence increase (to unphysical values) and then drop later on even further downstream? I also want to know (but can't seem to find online) what does FLUENT do with the turbulence boundary conditions? Be it turbulent intensity and (hydraulic diameter/length scale/viscosity ratio). How does FLUENT use these values for its calculation? Edit: If it matters, it's a pressure inlet of 1.8bars to pressure outlet of 0bars over a pipe length of 140m. Last edited by heng03313; August 10, 2015 at 14:22. Reason: added additional info |
August 10, 2015, 15:04 |
#2 | ||
Lucky
Rep Power: 66 |
Depending on the method that you use, you are specifying a constant value of TI at the inlet which is non-physical (since TI% increases towards the wall, reaches a maximum, and then decays to 0 at the wall). Garbage in, garbage out. Also, TI% is a local variable and TI% of 25-50% near walls is not unusual. I guess your concern is that the TI% over a cross-section is too high? Quote:
Inlet boundary conditions for turbulence changing | robboflea | FLUENT | 6 | April 7, 2022 14:37 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 01:54 |
Boundary Conditions | Jan Ramboer | Main CFD Forum | 11 | August 16, 1999 08:59 |
