how can make normal shock in the nozzle at inlet B.C : Pressure Far field
Like Tree1Likes
  • 1 Post By SonicGhoul
Old   August 18, 2015, 09:54
Question how can make normal shock in the nozzle at inlet B.C : Pressure Far field
Hongseok Yoo
SonicGhoul is on a distinguished road
hi, everyone. i have some questions.
first, im using B.C Pressure inlet/outlet, i can make normal shock in the nozzle.
its unsteady flow. so normal shock is keep moving forward.
but, im using B.C Pressure Far field / Pressure outlet, i cant make normal shock in the nozzle.
it's just supersonic flow in the nozzle and oblique shock is appear
i wanna make inlet flow mach number 3.0 and outlet flow mach number 0.4.
so, changing the supersonic flow to subsonic flow.
but i cant do it.
i founded some Sentence from the fluent help mannual.
Pressure outlet boundary conditions require the specification of a static (gauge) pressure at the outlet boundary. The value of the specified static pressure is used only while the flow is subsonic. Should the flow become locally supersonic, the specified pressure will no longer be used; pressure will be extrapolated from the flow in the interior.
so, i understand, pressure outlet's gauge pressure is ignored at supersonic flow.
how can make normal shock in the nozzle at inlet B.C : Pressure Far field??
Perhaps... Pressure Far field is not acceptable??
any suggestion. please help me.
saeed144 likes this.
SonicGhoul is offline   Reply With Quote
Old   March 3, 2016, 08:26
Default same problem
saeed144 is on a distinguished road
but i cant do it.
Pleaaaase
I have the same problem
have you solved yours
can you help me
can someone pleaaase help me
saeed144 is offline   Reply With Quote
Old   May 8, 2016, 05:16
Default Help please
No one has any suggestions?
it became an annoying problem
I am trying to fix inlet and outlet mach numbers in a converging-diverging diffuser, the parameters are set by the mean of pressure inlet/outlet boundaries. the values at these boundaries are pre-calculated by the inviscid quasi 2dimensional relations and normal and oblique shock relations.
the problem is that after some iterations, mach number at the inlet decreases to subsonic and the supersonic diffuser acts like a nuzzle
so the flow enters subsonic and leaves the channel supersonic, which exactly the opposite of what i want to simulate
please, help me
normal shock, pressure outlet, supersonic flow, terminal shock
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 22:46
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
