VOF/Capillary Rise has incorrect height
Old   August 27, 2015, 11:37
Default VOF/Capillary Rise has incorrect height
Ashley Byers
AshleyB is on a distinguished road
Hey there
I am doing a 2-d axi-symmetric case with water in a capillary. I'm just trying to verify against the Lucas-Washburn equation. Water is going much, much farther in the capillary than the analytical solution. It is not even close.
-My mesh is on the +x-axis, gravity in the -x-axis.
-Using VOF model, explicit scheme
-Piso coupling
-Courant number is 0.6 which lead to t~1e-6 which I feel is sufficiently small
-Surface Tension 0.07 N/m
-Contact angle 70 degrees
-Pipe radius of 0.3 mm
-Pressure Inlet and pressure outlet are both at gauge 0
This should go about 16 mm, but it does not. Does anyone have any idea why?
Also, what is an acceptable residual for this problem?
Thanks in advance for any help.
AshleyB is offline   Reply With Quote
Old   April 28, 2016, 12:36
Andrea
guigui2209 is on a distinguished road
Hi, did you find a solution for your problem? I'm doing the same case and for me it's the opposite, in the simulation water is much lower than in the lucas-washburn equation. I have almost the same configuration as you have, but instead of 70 degrees I have 0 because is the contact angle between water and glass
guigui2209 is offline   Reply With Quote
Old   April 28, 2016, 14:25
Ashley Byers
Andrea
In the operating conditions I clicked the operating density box and put in the density of air. After reading fluent guides, if I am not mistaken, if you do not click this box it will automatically take the average over cells, which for water and air would be totally inaccurate. Hopefully this helps, otherwise there may be a problem with initial conditions. Good luck!
axisymmetric, capillary, fluent 15.0, height, vof
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
Prismatic boundary layer KateEisenhower enGrid 5 September 15, 2015 07:48
urgent problem : fluid height ounifiras FLOW-3D 6 December 9, 2013 17:17
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 00:02
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
