SuSp as filed function
Old   September 2, 2015, 19:47
Default SuSp as filed function
IRP
iman
IRP is on a distinguished road
Dear all
I am dealing with a problem in Star-CCM+, about the impact of droplet on a surface in which I have to insert a phase source as a filed function for considering the wetting condition of wall boundary.
Actually, I am going to provide phase source as a filed function in which whenever the surface becomes wet, permanently it stays wet.
I find a way in chapter 9 of a book
• An introduction to computational fluid dynamic: the finite volume method
H. K. Versteeg & W. Malalasekera
Which relates to the implementation of boundary condition.
At the beginning of this chapter, it gives the idea:
if we want to fix the flux of a variable at a cell face, can be done by introducing two overwhelmingly large source terms in the relevant discretised equation. For example, to set the variable Q at node P to a value Qfix the following source term modification is used in its discretised equation:
Sp = -10^30 and Su = 10^30 * Qfix
With these sources added to the discretised equation, we have:
(ap + 10^30) Qp = Sum (anb*Qnb) + 10^30 * Qfix
The actual magnitude of the number 10^30 is arbitrary as long as it is very large compared with all the coefficients in the original discretized equation. Thus, if ap and anb are all negligible the discretized equation effectively states that
Qp = Q fix
Which fixes the value of Q at P.
I would be appreciated if anyone could help me to that what kind of filed function would be suitable in this condition (star- CCM+).
Thank you very much in advance.
Iman
IRP is offline   Reply With Quote
Lets talk about relaxation factor optimization chriss85 OpenFOAM Running, Solving & CFD 35 June 21, 2019 09:54
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
