Negative moment coefficient
Old   September 3, 2015, 10:37
Default Negative moment coefficient
Ronald Thompson
dynamic is on a distinguished road
I'm running transient analysis on a three bladed vertical axis wind turbine in 2d using fluent, the issue i'm having is that the moment coefficient is fluctuating between positive and negative values, See attached.
I also have attached plots of the mesh and a pressure contour which shows no large discontinuities.
Im using the transitional turbulence model with a "simple" scheme and second order upwind.
I have my reference values set up as follows
Depth = 1
Length = radius of turbine
Area = diameter of Turbine X length of blades.
If anyone could provide me with help it would be greatly appreciated, thanks in advance
dynamic is offline   Reply With Quote
Old   September 7, 2015, 06:38
Ronald Thompson
Can anybody assist? it's been wrecking my head for a long time now,
thanks
Old   September 14, 2015, 06:19
Ronald Thompson
thanks
Old   September 15, 2015, 01:24
Bharatt's Avatar
Bharat
Bharatt is on a distinguished road
Hi Thompson,
i am not sure/conclude with data you have provided. but for your better understanding please go through this tutorial.
http://www.cfd-online.com/Forums/ans...-tutorial.html
hope this will help.
cheers,
bharat
chapter 3:
-crossing the threshold-
Bharatt is offline   Reply With Quote
Old   September 15, 2015, 06:03
Ronald Thompson
Hi Bharatt,
Thank you for your reply. unfortunately the link to the web site provided is dead, however when i was initially setting up my model I followed the instructions provided by daysley in the .doc file.
This is why I'm thinking the issue may be down to how I have defined my reference values? Could you have a look at how I have them defined and let me know.
Very much appreciate your help
Old   September 15, 2015, 10:41
Andrew Kokemoor
Kokemoor is on a distinguished road
If you're unsure of your reference values, you can always look at the raw moment data and calculate the moment coefficient yourself. If it doesn't match what Fluent reports, then something's off.
In this case, though, reference values definitely aren't the problem. Reference values are just scaling dimensions; they won't change the sign. It looks to me like your oscillations are decreasing each cycle, do they get better if you solve farther? I don't know much about VAWTs, but it seems plausible that that could be the correct behavior. How does the time-averaged power match the theory?
Kokemoor is offline   Reply With Quote
Old   September 24, 2015, 14:47
Dri
Adriana
Dri is on a distinguished road
Depth = 1
I agree with Kokemoor. The reference values are not the problem. I had a similar problem and I found that reference frame from the solution initialization tab required to be absolute instead of relative to cell zone. Hope this helps.
Dri is offline   Reply With Quote
Old   September 24, 2015, 16:02
Ahmed Jalal
A.Jalal is on a distinguished road
You said it is a transient problem. How long are you running this for?
Try increasing the time steps for your solution to stabilize as it looks like the differences are decreasing.
A.Jalal is offline   Reply With Quote
Old   October 27, 2015, 17:11
Ronald Thompson
Hi Folks thanks for your replies to my problem
[QUOTE
In this case, though, reference values definitely aren't the problem. Reference values are just scaling dimensions; they won't change the sign. It looks to me like your oscillations are decreasing each cycle, do they get better if you solve farther? I don't know much about VAWTs, but it seems plausible that that could be the correct behavior. How does the time-averaged power match the theory?[/QUOTE]
Thanks for explaining why the reference values aren't the problem, I have run the solution for sufficient time for 4 full turbine rotations to occur, and my solution doesn't really get much better, I am not looking for the solution to converge just that I get a positive cm average for the last rotation as I'm neglecting the first three.
I personally taught my mesh was sufficient what is your opinion on this?
where else could I be having a problem.
Thanks for this but it didn't fix my problem unfortunately
Old   July 18, 2020, 02:11
Harshi Bavishi
HarshiBavishi is on a distinguished road
While analysing a 3D wing what is reference radius in moment calculation of a wing?
HarshiBavishi is offline   Reply With Quote
fluent 14.5, moment coefficient, monitors, negative moment, vawt wind turbine
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
