September 12, 2015, 01:38 |
Time saving or consuming FLUENt
sachindra
Hi friends. I have a question. Is FLUENT time consuming or time saving software. Because when we solve a steady flow problem then it takes few minutes to converge but when we go for unsteady problem it will take more than a weak. Then What can we categorize this time factor in FLUENT. I need the the answer from any FLUENT people
September 12, 2015, 03:50 |
#2 | |
amirhossein
Rep Power: 11 |
i think it's depend on your problem and also time step setting |
September 15, 2015, 23:20 |
Lucky
Rep Power: 66 |
The time-saving vs time-consuming is more related to your modelling approach than the software.
Basically, a steady simulation is an unsteady simulation with only 1 time-step (but very large dt). It depends on whether there is any time-scale to your problem. If your problem is stationary, then the choice of dt doesn't matter explicitly and the computational cost of an unsteady versus steady simulation scales with the total number of iterations that you perform: For unsteady: number of time steps x number of iterations per time-step vs For steady: number of iterations But if your problem has transients and you are trying to arrive at a stationary point (i.e. reach steady state) then the number of time-steps needed is proportional to the time-scale of the transient process (e.g. the time-constant of the problem). If you choose to model your problem in an expensive way, then it will become an expensive problem. |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
