Wang Fei-Long
Rep Power: 11 ![]() |
Hi everyone,
How can I change the wall thickness with UDFs? As the wall thickness is different in every cell face. Hope someone can give me some tips. Thanks in advance. Wang Fei-Long |
Bruno Machado
Rep Power: 13 ![]() |
I think the only way to change it besides manually is using it as a parameter.
#3 | |
Wang Fei-Long
I've never used the parameter. Is it possible to solve the problem? As the wall thickness of every cell surface on the wall was stored in the UDMs. Can I read the UDMs with the parameter? Can you help me please? Thank you! |
Bruno Machado
I never used parameters as well. I think you can get the parameter value to use in your UDF, but unfortunately I cant help you with that.
Wang Fei-Long
UDF to change heat transfer coefficient with wall temperature | emmkell | Fluent UDF and Scheme Programming | 18 | August 7, 2018 03:44 |
Wall thickness | magicalmarshmallow | FLUENT | 0 | June 4, 2014 09:29 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 06:23 |
film thickness using cell wall distance | RAHULME | FLUENT | 0 | June 27, 2011 07:25 |
