October 23, 2015, 04:18 |
Time-step clarification
Rahul
Rep Power: 10 |
I am currently working ln CFD simulation of combustion.I am doing combustion simulation of kirloskar TAF1 with sector type. The problem is i want to simulate combustion from crank angle 570 to 833.Fluent is taking 1428 time steps for solving the problem.By default,the max iterations/per step is set to 50 If 50 iterations are run per time step in the scale of crank angle 570.25,570.5 ,570.75,571upto 833. The total time taken for solving would be incredibly high My question is can i reduce the number of max. iterations per time step and get the optimal results for combustion simulation Can you recommend to which value should i set the max. Iterations per time step Thanks in advance!!! |
October 24, 2015, 14:35 |
Lucky
Rep Power: 66 |
Yes but just check to make sure your simulation is converged at the end of each time step. I generally try to aim for 20 iterations per time step but many people go as low as 8-10.
October 25, 2015, 03:53 |
Rahul
Rep Power: 10 |
Thank you very much for the information mate.But is there any way to reduce computational time bcoz
my simulation takes 1268 time steps for solving.this would take nearly 3 days to get solution.!! |
October 25, 2015, 21:51 |
Lucky
Rep Power: 66 |
Run a bigger time-step, larger crank angle steps. Run on more cores. Using a coarser mesh helps tremendously.
3 days is not very long, it's fairly reasonable for a detailed time-accurate problem. I've left a simulation alone to run for 9 months before. |
October 26, 2015, 03:28 |
Rahul
Rep Power: 10 |
Thanks a lot for your valuable inputs mate.Obviously, this is my first year in masters degree in CFD.I thought that it would run in a short time.
November 19, 2015, 01:00 |
Problem uploading UDF
Pradeep
Rep Power: 11 |
The time-displacement UDF could not be given to define the mesh motion of Kirloskar TAF1..Kindly help in moving the mesh. Thanks in Advance.!
combustion, fluent, ic engine, time step |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
