October 23, 2015, 06:36 |
Compressible flow boundary conditions
Rep Power: 10 |
I am trying to analyse the behavior of the engine exhaust gas in a structural facility, with wind conditions. For the effect I am using compressible flow, but I am having trouble in the boundary conditions in the volume of control. I was thinking about velocity inlet and pressure outlet, however that is not valid for compressible. I have tried pressure inlet and pressure outlet, and mass flow inlet and pressure outlet however nothing is working very well. Any suggestions? Thank you |
October 24, 2015, 14:02 |
Lucky
Rep Power: 66 |
A pressure inlet and pressure outlet pair are generally the most robust. For compressible flows you'll have to specify the inlet stagnation pressure (& stagnation temperature). If you need a particular mass-flow rate then use the target mass flow rate option on the pressure outlet. If this doesn't work, then you're probably doing something wrong.
October 26, 2015, 07:01 |
Rep Power: 10 |
This issue is - I do have convergence, but the problem is symmetrical and I am obtaining asymmetric results for the airflow. That only happens in 2nd order. I am using pressure standard and the results are getting better, but I don't understand the reason behind it.
October 28, 2015, 09:09 |
Philipp
Rep Power: 26 |
Can you post some pictures?
The skeleton ran out of shampoo in the shower. |
boundary conditions, compressible |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Boundary conditions for compressible flow | cici | Main CFD Forum | 1 | April 29, 2013 01:03 |
compressible flow boundary conditions | yangqing | FLUENT | 2 | January 22, 2002 10:19 |
