Pressure boundary conditions
Old   November 24, 2015, 17:36
Default Pressure boundary conditions
Martin Nolan
mnolan93 is on a distinguished road
Hi all,
I need to calculate flow rate from a 2d pipe. The 'total' pressure difference between inlet and outlet is only 1 pascal. The pressure inlet be asks me to define total gauge pressure, which is fine. However outlet says only gauge pressure - I presume static pressure. Using a value of 1 pascal less than the inlet BC does not give me accurate results vs theoretical results. Can anyone advise?
Thank you
mnolan93 is offline   Reply With Quote
Old   November 25, 2015, 01:47
sadjad.s's Avatar
sadjad
sadjad.s is on a distinguished road
Send a message via Yahoo to sadjad.s
hi mate,
pressure outlet is static pressure for flow going out of domain.
do you have any reverse flow?
ICEM, CFX and Fluent expert
sadjad.s is offline   Reply With Quote
Old   November 25, 2015, 02:28
Martin Nolan
Originally Posted by sadjad.s View Post
hi mate,
I have no reverse flow
Cheers!
Old   November 25, 2015, 02:54
sadjad.s's Avatar
sadjad
try using velocity inlet and then calculate delta P across domain.
how much is your error?
Old   November 25, 2015, 03:12
Martin Nolan
The delta P must be 1 :/ the error is 5 orders of magnitude as well...
Old   November 25, 2015, 08:22
Martin Nolan
Is there anyway I can ensure that the Total pressure difference between the inlet and outlet is 1Pa? I seem to be getting big changes in pressures
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
Help with pressure boundary conditions Stephen Waite FLUENT 0 September 12, 2013 05:45
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 17:15
