Laminar Finite rate Model - Over predicting temperature (3300 K) |
December 18, 2015, 17:43 |
Geralt
Hi everyone,
I am trying to model laminar diffusion flame for methane combustion. The geometry is simple with center input methane jet (300 K , 0.5 m/s) surrounded by coflow input air(300 kelvin,0.1 m/sec) I simulate non-reacting flows, after achieving convergence, I patch 2500 K high temperature zone for ignition and let it run with Laminar finite rate model and stiff chemistry activated. I tried both 2 step methane-air reaction and one step methane-air reaction. In both the cases the maximum temperature predicted is 3300K and 3200 K respectively. I used mixing law for Cp calculation of the mixture. Individual Species enthalpy are calculated by Piece wise polynomial. I have seen many posts realted to this issue. Has anyone found a way to get temperature down to 2200 K ? I tried similar case with Eddy disspiation model where temperature prediction was 2100K. (I know EDM is for turbulent cases) Thank you |
August 30, 2017, 05:32 |
#2 | |
mengke zhan
I am also using laminar finite-rate to model a pre-mixed combustion between propane and air. However, I don't seem to get the sustained flame. The temperature returned to 300k soon after patching (3000k at the inlet). I am wondering what might be the problem here. Could you help? Thanksss!!! Mengke Quote:
combustion modeling, high temperature, laminar diffusion flame, methane-air |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
gamma-ReTheta turbulence model for predicting transitional flows | FelixL | OpenFOAM Programming & Development | 123 | August 30, 2022 11:50 |
Solid Temperature in Non Equilibrium Model | rolloblues | CFX | 7 | November 7, 2013 08:46 |
Surface reaction rate temperature dependence | tumbao | FLUENT | 1 | February 17, 2011 09:14 |
