problem in the calculation of pressure drop for an axial turbine
Old   January 1, 2016, 14:07
Default problem in the calculation of pressure drop for an axial turbine
Aja
aja1345 is on a distinguished road
I am simulating an axial turbine. In this turbine, there are two domains.
The first domain is the piping before and after the blade and the second domain contains the turbine blades. The domain containing the blades rotates at 2000 rpm=209.43 rad/s while the other one is stationary.
I validated torque of turbine with experimental values but pressure drop at inlet and outlet of turbine doesn't validate with experimental value correctly. In fact, pressure drop is law and it should be higher. How do i solve this problem?
I am grateful that guide me about this case.
Aja
aja1345 is offline   Reply With Quote
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
inlet has higher pressure than outlet in axial flow fan sivakumar Main CFD Forum 37 July 21, 2014 08:34
Axial fan Efficiency Goals calculation? Sanghyun - PARK FloEFD, FloWorks & FloTHERM 1 February 18, 2013 11:20
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 17:49
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
