January 5, 2016, 17:02 |
Dynamic viscosity and Kinematic viscosity
Astio Lamar
Rep Power: 14 |
Hello everybody!
I am confused with Dynamic viscosity and Kinematic viscosity in FLUENT! as we know: unit of Dynamic viscosity in SI is kg/m.s and unit of Kinematic viscosity in SI is m2/s in FLUENT under "Reference Values" there is a Viscosity with unit kg/m.s according to the unit this viscosity should be "Dynamic viscosity", but when I check the Fluent manual, it said: sets the reference kinematic viscosity, which is used in the computation of the boundary Reynolds number. Can someone explain this to me?! why "kinematic viscosity" has unit of "Dynamic viscosity" in FLUENT?!!!!! Thanks. |
January 6, 2016, 15:29 |
Lucky
Rep Power: 66 |
In Fluent User's Guide 33.11.1 Setting Reference Values it clearly states dynamic viscosity in my manual.
January 6, 2016, 17:17 |
#4 | |
Yeah. It seems to me that some old manuals and theory guides had some amount of typing errors. I especially noticed this when I was writing a turbulence model in OpenFoam by looking at Fluent theory guide., there is a post in OpenFoam forum by roriguez indicating some of these typos. |
January 6, 2016, 17:47 |
Astio Lamar
Rep Power: 14 |
Hello and thanks for your comments
If you see the section: 35.11. Reference Values Task Page it clearly written: Viscosity sets the reference kinematic viscosity, which is used in the computation of the boundary Reynolds number. see the attached figure and See this link also: http://aerojet.engr.ucdavis.edu/flue...ference_Values |
January 6, 2016, 21:56 |
Rep Power: 18 |
It's most likely a typo in that section of the users guide. In section 32.11.1 they've correctly labelled it as dynamic viscosity.
January 8, 2016, 22:38 |
#7 | |
Lucky
Rep Power: 66 |
September 3, 2019, 01:25 |
Hojatollah Gholami
Rep Power: 7 |
In fluent, for non-Newtonian fluid, the dimension that used for Consistency Index "k" is [kg-s^n-2/m]. How can convert it to kg/m-s or m^2/s? Why they uses |
Fluent follows which viscosity dynamic or kinematic? | rsdsaurav | FLUENT | 1 | June 26, 2016 11:18 |
Dynamic Viscosity at transportproperties dictionary | NickolasPl | Main CFD Forum | 0 | June 2, 2011 14:06 |
User-defined turbulent viscosity - kinematic or dynamic? | tstorm | Main CFD Forum | 4 | January 29, 2010 11:08 |
User-defined turbulent viscosity - kinematic or dynamic? | tstorm | FLUENT | 0 | August 13, 2009 16:49 |
kinematic viscosity at diff temperatures,pressures | Mecobio | Main CFD Forum | 0 | November 7, 2005 12:55 |
