Simulation of flow with particles in hydraulic fracturing applicaiton
Old   January 27, 2016, 19:19
Default Simulation of flow with particles in hydraulic fracturing applicaiton
Rolanzo
Rolanzo is on a distinguished road
Hi, I am a graduate student in petroleum engineering working on hydraulic fracturing simulation, which basically in this case is just a flow of liquid (water) with some particles (low concentration) thru the fractures already been created, we want to look at particle concentration in each fracture. The domain of interest would look something like attached file. I am a very new Fluent user, so I dont have much knowledge about it. I have already done the simulation with using just some basic setup with standard turbulent model in Fluent with DPM model, particles are continuously injected throughout the simulation, and gravitational effect is on. I have obtained the result as shown in attached files, but I am not sure if the result is correct as the particles only going down not going to left or right at all even from the beginning, the trend would always looks something like attached file. Please note that the scale of the simulation is very big, fracture length is in order of 150 ft, the width is only about 0.8-1 inch, and the pipe diameter is only 6 inch.
Please kindly advise if there are any other important factors that I should consider in the simulation to make it more accurate.
http://s8.postimg.org/s2l7hhayt/image.jpg
http://s28.postimg.org/pm39m2zql/HF3.jpg
http://s30.postimg.org/j7wokh169/HF4.jpg
Thank you.
Last edited by Rolanzo; January 27, 2016 at 19:23. Reason: Changing attached files directory
Rolanzo is offline   Reply With Quote
Old   May 20, 2016, 02:12
Mortatha
Mortatha is on a distinguished road
how you design the hydraulic fracture???
Mortatha is offline   Reply With Quote
cfd hydraulic fracturing
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
mass flow rate issue in supersonic nozzle simulation xkang FLUENT 0 July 31, 2014 16:06
Comparison between Solidworks Flow Simulation and Ansys Fluent Bruce828 Main CFD Forum 5 February 23, 2013 10:13
Differences and functions of Solidworks Simulation and Solidworks Flow Simulation? alpharays Main CFD Forum 0 April 19, 2012 03:13
Importance of Hydraulic Diameter Value for Compressible Flow RyGuy FLUENT 0 August 6, 2009 10:58
