February 1, 2016, 18:25 |
heat transfer between two fluids
André Ricardo
Hi
I'm simulating a heat exchanger, but I'm having trouble with the thermal part. With few interactions my problem presents a satisfactory result (100 for example), but when you put many interactions (1000 for example) it presents a very unsatisfactory outcome for example my fluid cold comes with temperature 300K and the hot fluid with temperature 350k at the end of the simulation my cold fluid has higher than the temperature of the hot fluid and this further increases in temperature. I tried to solve the simplest cases where the solution converges with few interactions but no heat exchange fluids none. I think it might be a wall condition. Can someone help me. |
heat exchanger two fluids |
CFX does not solve heat transfer at fluid-solid interfaces | Ivan Corgozinho | CFX | 2 | April 7, 2015 00:08 |
Radiation heat transfer boundary condition | natrask | OpenFOAM Programming & Development | 0 | February 8, 2015 09:05 |
Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 17, 2014 23:45 |
radiation heat transfer | GeHa | FLUENT | 1 | September 5, 2012 14:56 |
Help with mass transfer in heat and water vapor exchanger | mullenc525 | CFX | 7 | January 25, 2011 23:26 |
