February 2, 2016, 05:51 |
Axisymmetric Error
Chris
When I switch my 2D space from planar to axisymmetric I get 3 floating point errors and it says divergence detected. How can I fix this issue? Also how can you analyse the gases produced in a combustion reaction in fluent?
Thanks |
August 20, 2016, 20:56 |
Axisymmetric Error
abhu
You should make another geometry. Make half part of your original geometry along X-axis. Make half portion of your geometry in +y axis direction.
axisymmetric, combustion, error, floating, gas |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
