Continuity Residual high but total mass convergence achieved?
Old   February 8, 2016, 06:21
Default Continuity Residual high but total mass convergence achieved?
MichaelStark331 is on a distinguished road
Hi everyone,
I'm working on designing an aerodynamics package for a Formula Student team and am relatively new to CFD. One thing that has been bothering me is a high continuity residual I am getting for my simulations. My x,y,z-velocity residuals are all around 1e-5, and my k and omega residuals steady around 1e-3. However, my scaled continuity residuals stays around 1e-2.
Despite this, my mass flow rate between my inlet and outlet only differs by 0.0005% (all other BCs are moving walls). I know that residuals are ideally meant to drop 3 orders of magnitude at least for convergence but Fluent's scale factor for the cont. equation depends on the first 5 iterations.
Would this high continuity residual be justified given the total mass of the wind tunnel has converged?
My BCs are:
Inlet (15m/s)
Pressure Outlet
Symmetry Plane
Roof (moving wall -> 15m/s)
Wall (moving wall -> 15m/s)
Ground (moving wall -> 15m/s)
MichaelStark331 is offline   Reply With Quote
Old   February 8, 2016, 10:24
Default Under-Relaxation factor
InduSekhar Roy
ELITEind is on a distinguished road
You can try decreasing the Under-Relaxation factor.
Setup-> Solution Controls ->
Try decreasing the "Under-Relaxation factor" for "momentum" from 0.7 to 0.6. You can try decreasing till 0.1, even 0.01. But, it is advised not decrease it below 0.1 to get accurate result.
http://www.cfd-online.com/Forums/flu...nvergence.html
I hope this helps.
ELITEind is offline   Reply With Quote
continuity, mass, residual, residuals
a problem with convergence in buoyantSimpleFoam skuznet OpenFOAM Running, Solving & CFD 6 November 15, 2017 12:12
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
