Correct method for calculating time step size |
February 9, 2016, 03:49 |
Aarthy Meena
Rep Power: 10 |
Hello Everyone,
I am a newbie to FLUENT & CFD. I wanted to calculate time step size for unsteady flow around a circular cylinder of dia = 0.01m in the Reynolds number of 45 to 50. The working fluid is water with viscosity = 0.001003 kg/ms and density = 998.2 kg/m3. I came across several posts related to this and many methods to calculate the time step size. 1) From Strouhal number (0.2 for circular cylinder- approx) Sr (0.2) = (frequency x diameter) / velocity From the above equation find the frequency. The total time period, T = 1/frequency. Hence, time step t = T/25 (approx). 2) From CFL condition t = C_m X x / velocity where, C_m = 1 (approx) and x = minimum cell size. 3)From domain length t = domain length / (20 x velocity) 1) Which of the above method is correct ? 2) How to calculate the suitable time step size for my condition? 3) Please explain. Thanks in advance.
Aarthy, PG Student, National Institute of Technology, Trichy, India. Last edited by Aarthy Meena; February 9, 2016 at 04:50. |
February 9, 2016, 04:25 |
Filippo Maria Denaro
Rep Power: 71 |
the time step is constrained by stability criteria that are based not only on the cfl condition but also on the visicous terms.
Furthermore, each discretization has a specific stability region |
February 9, 2016, 04:28 |
Aarthy Meena
Rep Power: 10 |
Dear Sir,
Can you please explain me the method for my flow scenario around a circular cylinder.
Aarthy, PG Student, National Institute of Technology, Trichy, India. |
February 9, 2016, 04:36 |
Rep Power: 71 |
The numerical stability depends upon the method you use for the integration and the sizes of the mesh (in all directions), does not depend on a specific flow problem.
Assuming you are using non-dimensional equations, the velocity magnitude is no more than O(1) so that you can use that as estimation in the (multidimensional) CFL condition |
February 9, 2016, 04:46 |
Aarthy Meena
Rep Power: 10 |
Thank you sir,
Actually am very new to FLUENT and I do not understand your reply. In FLUENT, I am using dimensional form of the governing equations. Kindly please suggest me some material where I can learn about this topic.
February 10, 2016, 03:20 |
Lucas
Rep Power: 10 |
A theoretical advice:
The CFL-number and the according "condition" are only part of the stability analysis of numerical schemes. A good introduction (for Finite Difference methods) can be found on: https://en.wikipedia.org/wiki/Von_Ne...ility_analysis Basically the stability depends on the equation you discretise (including all the terms in it - as FMDemaro added), as well as the discretisation scheme you use. As a "rule of thumb": lower order discretisation schemes (e.g.: Upwind schemes) and implicit time-dependent solution are very stable, whereas the more accurate methods tend to be unstable. For the Finite Element method, this can be proven analytically for certain cases - An example is also contained in the link. A practical advice: I am not familiar with ANSYS Fluent but I guess, that you will use Finite Volume Method with an implicit solver. The theoretical advice from above might therefore be tough to prove for your problem. I would advise you to have look on the user manual and see, if there is any hint. A cylinder in cross flow is also very well researched and there might be a lot of data and advice for your example already available. Regards, Lucas |
February 10, 2016, 04:46 |
Help please!!
Ravi
I am trying to do a transient analysis of flow through a bifurcation of penstock pipe (wye) using ansys cfx . Here i need to specify the conditions that the valves of the turbine are closed within a 5 seconds of time. I thought of giving pressure inlet and mass flow rate at the outlet. Now i need to vary the mass flow rate at the outlet from 4650kg/s to 0 within a 5 seconds of time and i dont know how to do that in ansys CFX. Can anybody help me please ??
May 7, 2019, 07:56 |
question
Rep Power: 7 |
Dear Aarthy Meena,
did you find a good average to calculate the time step and time step size? |
circular cylinder, fluent 14.5, time step size, transient simulations |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
