Need urgent help
Old   February 12, 2016, 23:45
Default Need urgent help
Niranjan
Niranjan is on a distinguished road
I have a CD Nozzle, it's inlet conditions are 940psi, 100m/s velocity, 3400K temperature. the exit conditions are normal room conditions. i wan't to conduct a simulation.
if i conduct a simulation, it is not accepting my temperature as 3400k. the fluent is giving an error. so i ran the simulation with 300k(room temperature)(same both for inlet and outlet.) , then the solution converges and i am getting an exit plane velocity of my nozzle as 640m/s. but i need an velocity of 1300m/s. i need to convert the temperature into velocity. can anyone help me??
Niranjan is offline   Reply With Quote
Old   February 13, 2016, 12:47
Lucky
What type of error are you getting from Fluent?
Old   February 14, 2016, 03:39
Default Problem solved
Niranjan
Thank you. Problem is solved
urgent!!! mesh and geometry melek FLOW-3D 0 August 26, 2013 10:10
Urgent - Polyflow - particle tracking visualization -Urgent shafaatht ANSYS 0 October 13, 2010 04:56
Urgent, Urgent, a UDF problem, PLEASE HELP!!! Max FLUENT 1 September 24, 2010 20:30
Urgent...urgent...plss!!! astronome FLUENT 0 October 16, 2009 07:17
tmerge urgent urgent jessica FLUENT 4 July 15, 2006 13:37
