cg-motion udf vs 6dof udf
Old   February 21, 2016, 00:09
Default cg-motion udf vs 6dof udf
arshia
hamed1987 is on a distinguished road
hi every one,
i want to simulate moving object inside a barrel by patching high pressure and tempreture ,
i used a 6dof udf and set prop[SDOF_MASS] = 0.4
and so i tried to check the moving by using cg-motion udf
that calculate the force and solve second law for motion:
force = 0.0;
begin_f_loop (f, t)
F_AREA (A, f, t);
force += 2*M_PI*F_P (f, t) * NV_MAG (A);
end_f_loop (f, t)
/* compute change in velocity, i.e., dv = F * dt / mass velocity update using explicit Euler formula */
dv = dtime * force / .4;
v_prev += dv;
Message ("time = %f, x_vel = %f, force = %f\n", time, v_prev, force); /* set x-component of velocity */
vel[0] = v_prev;
but when i checked the velocities at the same position for example
@ x=.2
vel object (6dof)=286
vel object (cg_motion)=86
any one know why???
hamed1987 is offline   Reply With Quote
Old   February 22, 2016, 05:20
arshia
any suggestions???
Parallelizing UDF for Mesh Motion avd28 Fluent UDF and Scheme Programming 2 September 23, 2017 05:20
incorrect grid motion UDF deforming on zone ?????? h.iraji FLUENT 0 October 29, 2013 02:43
Is this the correct approach to my problem? (UDF for object in motion) charlestan88 Fluent UDF and Scheme Programming 5 October 27, 2013 06:09
Motion UDF kailingkk Fluent UDF and Scheme Programming 0 October 15, 2013 10:56
UDF error CG Motion Alex FLUENT 0 March 22, 2006 17:40
