April 28, 2017, 09:57 |
Unable to start the geometry editor.
#21 |
Getachew Neme
I Installed Ansys 17.0 on new machine (Dell Precision Tower 5810, Windows 10 Pro, 64 bit system). I installed the Ansysy successfully and I couldn't run the Design Modeller due to the error "Unable to start the geometry editor". Please, any help to fix my problem?
Kindly request, |
August 14, 2017, 17:07 |
#22 |
Thiago
Rep Power: 9 |
mehaque101 ,
Did you solve the problem? I have the same problem, but with ansys 18. |
August 14, 2017, 17:09 |
same problem with ansys license manager release 18
#23 | |
Thiago
Rep Power: 9 |
August 14, 2017, 20:01 |
#24 |
Rep Power: 11 |
[GeomEditorTimeOut:DMAddin] Unable to start the geometry editor.
There is the same question posted, but I don't know if it's solved. you can try it and respond the results in the thread. |
August 14, 2017, 21:21 |
#25 | |
Lucky
Rep Power: 66 |
Did you have a previous version of Fluent installed? Make sure you've followed the instructions to remove the old license manager. Uninstalling Ansys doesn't remove the license manager. You can quickly check your environmental variables to see if old information is there. For debugging I recommend to only tinker with the ANSYS License Management Center because it's a standlone process. Don't do anything weird like trying to launch workbench of design modeler or anything. If the license manager processes does not launch, nothing will work. |
August 15, 2017, 02:12 |
#26 | |
Getachew Neme
Yes I fixed the problem as of the following: C:\Program Files\ANSYS Inc\v170\ProductConfig I configured all the important programs and then restarted my PC. It worked after then. |
August 15, 2017, 10:49 |
#27 | |
Thiago
Rep Power: 9 |
Yes, I was able to install in my notebook that has win7, but in this one that has win 10 pro is not working ... before installing I uninstalled everything that was old and installed all the pre requisites ... I no longer know what to do ... I've tried everything ... I think it's something related to win 10 ... but I do not know how to solve it .. |
August 15, 2017, 10:51 |
#28 |
Thiago
Rep Power: 9 |
August 15, 2017, 20:09 |
#30 | |
Lucky
Rep Power: 66 |
Also, you really should be contacting Ansys support. After all, you or your company has already paid good money to use their stuff. Why did you spend all this money if you can't even install the darn thing? The only thing you need to get support is the customer ID, which you should always have. |
November 28, 2020, 19:06 |
ProductConfig works for me.
#31 | |
anonim
Works well for me, thanks . Note : version 16 on Windows 10 Pro 19041.630. Likely cause are OS upgrade from Home to Pro and some following updates. |
