April 26, 2016, 16:54 |
UDF for velocity field
vahid
i'm working on a CFD code in which velocity field is given to me,
to verify my code i decided to use fluent, can i insert my velocity field in fluent by defining a UDF or other means? |
April 27, 2016, 20:26 |
Lucky
Rep Power: 66 |
If you already have the velocity field, then what is there left to do?
There's lots of ways to get a velocity field. Using a profile is probably the easiest. Or you could import it using an interpolate file, which is pretty much a delimited file of x,y,z coordinates and variables. |
[SOWFA] NREL SOWFA ABLTerrainSolver tutorial problem | cico0815 | OpenFOAM Community Contributions | 36 | February 3, 2022 11:54 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Steady simulation does not iterate in Time=1 | agustinvo | OpenFOAM Running, Solving & CFD | 3 | November 19, 2015 04:57 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
I need UDF help. | S.Whitney | FLUENT | 0 | October 15, 2007 11:29 |
