April 28, 2016, 02:31 |
AMG solver divergent
Reza Rahnama
Hi everybody
i am working on a case that models sterlization of a fermentor with steam.modeling consitions and setups are listed below: Density based Transient and multiphae (wetsteam) Boundary Conditions are pressure inlet= 2 bar, 233 C and pressure outlet=1.6 bar, 129 C I used inviscid flow soloution method is implicit when i start to calculate and run the case after about 5-15 iteration, solution diverge and i face to listed errors : # Divergence detected in AMG solver: > Increasing relaxation sweeps! # Divergence detected in AMG solver: Coupled -> Decreasing coarsening group size! Divergence detected in AMG solver: WSB-eq Divergence detected in AMG solver: WSN-eq can anybody help me to resole this problem? |
April 29, 2016, 17:08 |
Lucky
Rep Power: 66 |
What does inviscid multiphase flow of wet steam even look like?
Anyway, since you are running a transient case and it diverged in 15 or so iterations, does that mean that it diverged on the very 1st iteration? Most likely, you have incorrect initial conditions or your mesh is really bad. I would check those first. Make sure your initial conditions for all variables are consistent. For transient simulations you often need to generate the initial conditions from another simulation. Also check your mesh quality. Run the mesh check and see if there are any glaring issues. |
amg solver, divergent, wsb-eq |
Fluent IcePak - AMG Solver | Russ | FLUENT | 2 | December 31, 2018 09:57 |
Divergence detected in AMG solver: temperature | R4RAHUL | FLUENT | 6 | September 16, 2014 17:44 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
reverse flow and divergence in AMG solver | MASOUD | FLUENT | 2 | April 2, 2010 08:48 |
AMG versus ICCG | msrinath80 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2006 15:15 |
