problem in dynamic mesh
Old   May 6, 2016, 23:58
Default problem in dynamic mesh
raj
raj aero is on a distinguished road
hello everyone,
i am doing transient analysis for predicting thermodynamic cycle of stirling heat pump. in which i have two moving body (piston and displacer).i compiled the UDF for piston and displacer motion. but, when i preview the mesh motion,the mesh is moving good up to some time step. after that i got the following error. can anyone help me to solve this error.
Thanks in advance....
"Updating mesh to time 1.40000e-03 (step = 00014)...
Node 1: Process 4976: Received signal SIGSEGV
Node 0: Process 5848: Received signal SIGSEGV.
MPI Application rank 2 exited before MPI_Finalize() with status 2
The fl process could not be started.
===============Message from the Cortex Process==
Fatal error in one of the compute process
Error: Cortex received a fatal signal (unrecognized signal).
Error Object: ()
raj aero is offline   Reply With Quote
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh Emanuele88 FLUENT 0 February 9, 2016 11:39
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 10:08
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 05:02
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
CFD-3D flow problem using Dynamic mesh method. Sar_mech FLUENT 1 November 27, 2008 21:17
