Backwards-Facing STEP: SIMPLEC vs Coupled Algorithms |
May 8, 2016, 08:12 |
Rep Power: 10 |
Hi all,
I am simulating a turbulent channel flow over a backwards-facing step. I have chosen to use RANS + standard k-w turbulence model (with low-Re corrections). My flow conditions are those from: Driver, D. & Seegmiller, H., 1985. Features of a reattaching turbulent shear layer in divergent channel flow. AIAA Journal, 23(2), pp. 163-171. with an inlet pipe length of 1m, outlet pipe length of 5.5m and a step height of 1.27cm. When I increase my mesh density such that y+ = 1, the SIMPLEC algorithm generates a converged solution only after about 18k iterations whereas the Coupled algorithm only after 3k iterations. In both cases I am using QUICK interpolation schemes. I have compared the two solutions and they are identical. I know that once low-Re corrections are enabled a converged solution is obtained harder as the equations for k-w are integrated in the boundary layer as well but what I don't understand is why SIMPLEC is slower than the Coupled algorithm. I am simulating an incompressible flow so it shouldn't be the case. I am suspecting that it may be due to the choice in turbulence modelling but I am not sure. Does anyone know any other potential causes for this? |
coupled, k-w-standard convergece, simplec, turbulence modelling |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
Laminar simulation with Simple Algorithms and Coupled Algorithms. | lienien | FLUENT | 4 | April 30, 2013 11:15 |
Rearward facing step simulations | siw | FLUENT | 1 | September 23, 2009 02:21 |
backward facing step problem | Yung-Ming Chen | Main CFD Forum | 3 | May 11, 1999 22:04 |
