May 12, 2016, 01:05 |
Propeller Fluent Analysis
SELANGOR, MALAYSIA
Rep Power: 10 |
Hi everyone,
I'm vry new to ANSYS Fluent. So basically I would want to run analysis to determine the aerodynamic properties of a 10 x 7 inch propeller blade. I've some questions: 1) Is it possible to run static propeller analysis? 2) If I would want to make it moving at certain RPM, how do I do it? 3) How do I run the analysis to determine the thrust and power coefficient of the blade? 4) Do I run it with laminar or turbulence? Since my Reynolds number at 75% is 50669 at 3000rpm. Do enlighten me please. Thank you in advance |
May 16, 2016, 04:44 |
Pedro
I am interested in the same thing as asking zize with the idea of extending a multirotor aircraft.
I try to up the thread to see if anyone can help . Thank you very much. |
May 16, 2016, 22:44 |
SELANGOR, MALAYSIA
Rep Power: 10 |
Did you manage to find the solutions?
Propeller flow simulation in Ansys Fluent | a1ananth | FLUENT | 2 | December 4, 2014 15:30 |
analysis of multiphase and porous media in ansys fluent | ahmed_khatibs | FLUENT | 0 | November 4, 2014 12:01 |
Flow Analysis Around Aircraft with Propeller Effect | theengineer | Mesh Generation & Pre-Processing | 0 | August 13, 2013 05:37 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
Turbulent Round Jet Fluent analysis | Renan Margonar | FLUENT | 3 | June 20, 2013 09:07 |
