Warning: boundary Mach number exceeds maximum limit on pressure-outlet-8 for 11 faces
Old   May 17, 2016, 05:33
Default Warning: boundary Mach number exceeds maximum limit on pressure-outlet-8 for 11 faces
Diger is on a distinguished road
So I'm having this warning and was wondering if it is of any importance.
The outlet where this happens is a small nozzle which large flow so that the flow speed comes close to the speed of sound is no surprise.
Though this only happens when I use the compressible ideal gas model.
When solving the incompressible equations this doesn't show up.
Also the flow through the nozzle is given by: 0.1724 g/s but the "converged" solution only calculates 0.16757728 g/s
would u call that in the errors or isn't the solution converging?
The residuals look fine!
Also the pathlines of the solution look to me - what I would expect.
Diger is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 14:53
Warning: boundary Mach number exceeds maximum limit on pressure-outlet Tarantino FLUENT 1 March 22, 2013 21:30
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
