FLUENT DPM unsteady particle time step VS injection time step
Old   May 19, 2016, 11:47
Default FLUENT DPM unsteady particle time step VS injection time step
wv1216 is on a distinguished road
The user manual says " You can either Inject Particles at Particle Time step or at the flow time step."
Is it possible to setup a user defined injection time step in unsteady tracking, which is different from the particle tracking time step?
For example, I want to study particles in its mean free path without any collisions.
I know the particle flow rate, say 1E7 particles injected per second. And I know the time corresponding to its mean free path say 1E-10s.
If I set the particle tracking time step is 1E-10s, then because of "injection time step=tracking time step", then I injected 1E-10s * 1E7/s =1E-3 particles. This is unphysical! The particle number should be integer, at least 1.
Who could provide some suggestion in the above scenario?
Thank you.
WW
wv1216 is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 07:09
time step directories naming issue Andrea_85 OpenFOAM 3 April 3, 2014 08:38
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
