CGNS error reported from FLUENT export in parallel processing |
May 23, 2016, 13:00 |
Emre G
Rep Power: 15 |
When I try to export cgns file format from (in acoustic mode), the paralel processing result and serial result differs from each other. CGNS files which of them are exported from PARALEL processing in fluent cant be read in softwares. But serial results are working. Is there any idea? Thanks |
May 25, 2016, 22:38 |
Lucky
Rep Power: 66 |
The parallel and serial results will be different. In parallel, it will export data from each partition separately.
I recommend to switch to serial mode and then export data. Otherwise, you will have to parse through the data file and merge the data back together again. You just need to realize that Fluent is exporting the data in blocks (each node exports it's own data and writes/appends it to the data file separately). How easy it is to implement this fix depends on what tool you're actually using to read the data files. |
June 22, 2016, 04:26 |
#3 | |
Emre G
Rep Power: 15 |
do you have any idea? thanks |
August 19, 2016, 22:25 |
Jingchang.Shi
Rep Power: 13 |
CGNS data files exported from parallel fluent contain values of zero. All fluid variables behave like this. Did you ever encounter this problem?
October 24, 2022, 11:00 |
Henry
Rep Power: 11 |
Hiya, I am encountering the same issue when I export the node data using parallel solvers. Do you happen to solve this problem (I know it's been a long time since your last post)? Many thanks in advance!
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
Parallel Processing in FLUENT | vigii | FLUENT | 7 | February 20, 2013 10:16 |
Parallel Processing by FLUENT? | M Kermani | Main CFD Forum | 2 | February 21, 2001 10:01 |
