mass inbalance despite good looking residuals |
Christian Mahr
Rep Power: 10 ![]() |
Hi everybody,
I am simulating an air flow in a circular periodic geometry. The model has 3 inlets and 1 outlet. I am using a mass flow profile at the inlets. As the flow should be considered as compressible near the inlets, I am using the density-based solver. I set a constant wall temperature as heat transfer through the walls shouldnt be simulated. My problem is, that all my residuals lowered to a range of 10^-6 to 10^-7, but still my mass imbalance is far away from being 1% of the smallest mass flow. In fact it is between 50 and 1000 % of the smallest inlet. I am using EWT and my Y+ are in between 1 and 3, in regions of the inlets, I have 10 boundary layers, at the outlet there are 5 BL. Could you tell, where I have to search the problem? Really would appreciate some good advices! All the best, Chri Last edited by chri; May 31, 2016 at 05:10. |
questions about species transport through walls | shuqin | FLUENT | 13 | April 9, 2014 02:42 |
what to monitor besides residuals? | franzdrs | FLUENT | 5 | March 21, 2013 03:59 |
judging convergence through residuals | MachZero | Main CFD Forum | 7 | December 25, 2012 12:18 |
Problem setting with chtmultiregionFoam | Antonin | OpenFOAM | 10 | April 24, 2012 09:50 |
particle, parcel and mass flow rate balance | flybird | FLUENT | 0 | May 24, 2007 10:44 |
