May 30, 2016, 09:41 |
Turbine performance overprediction
John Smyth
Rep Power: 10 |
Hi Folks,
I'm trying to carryout transient analysis on a 2D 3 bladed vertical axis wind turbine. I want to then compare my CFD to experimental Cp results. Im determining my Cp by multiplying my Cm (based off the reference values) by the tip speed ratio. Cp = Cm X TSR I've found this is what alot of published authors have done. Im using the SST turbulence model with a Y+ =1 I reckon my mesh is pretty good with 1000 elements over each foil of 0.14 m chord and a total domain siz of ~300k elements with a max skewness of 0.76 Im using the Coupled Scheme and a Courant number of 100 aswell as the Presto model for pressure, this gives me a max Cp of 0.6 wheres it should be 0.3 according to experimental, Im aware that 2 D models will overpredict the performance and they are unable to capture 3D blade tip effect etc. but I was hoping to get a better solution that 100% over prediction. Also when I run the second order model for pressure after about 3000 iteritions i get the warning "turbulent viscosity limited to viscosity ratio of 1.000000e+05 in xxxcells" with x increasing until I get divergence and a floating point exception and failure. has anyone any experience in this id appreciate any advice, or can explain why the Presto model works and the 2nd order doesnt? I also have this problem when I try to run Piso instead of Coupled. Thanks any advice would be appreciated. Thanks, John |
coupled solver, presto, transient 2d, turbulent, vawt wind turbine |
Problem with torque output from a turbine simulation. | pa-dundas | FLUENT | 5 | July 17, 2022 05:27 |
A error when take Gas turbine performance? | prayskyer | CFX | 1 | October 28, 2015 09:16 |
6dof for rotation of turbine: unable to fix the center | Havinh | Fluent UDF and Scheme Programming | 0 | August 5, 2015 05:35 |
I'm doing something about the aerodynamic performance of wind turbine airfoil with Fl | shlgzz | FLUENT | 11 | January 15, 2013 21:29 |
how can i get axail turbine performance in cfx-pos | dia aisa | CFX | 3 | June 27, 2008 07:56 |
