v2f turbulent model
Old   July 11, 2016, 16:31
Unhappy v2f turbulent model
hamide hayati
hamide is on a distinguished road
hi all
i want to simulate turbulent flow in a 2D channel (2*40cm) by v2f model.
i set it as follow:
-i try to use fine mesh near the wall, (y+<=1)
-B.C : velocity inlet, v=5 m/s , and define functions for v,k,epsilon and v2.(to be fully developed from beginning of channel)
outFlow for end of the channel
nosleep fo walls.
-second order upwind to solve equations.
but unfortunately i can't valid my results!!!!!! for example i can't find u+ vs y+ graph correctly!!! and also v'+ vs y+ and k+ vs y+ near the wall!!!!(1<y+<100)
i don't know what the problem is!!!!
is there any one help me to handle this problem.
hamide is offline   Reply With Quote
k-omega-SST model (OF 1.6) - turbulent flat plate cboss OpenFOAM Running, Solving & CFD 25 August 9, 2016 09:53
porous media turbulent model P-dL, I get the different results? is the model wrong? hitchenxue FLUENT 0 July 13, 2014 05:57
Use of laminar model for a turbulent flow jcamilleri Main CFD Forum 1 July 6, 2014 06:54
Error - simplefoam when running turbulent model twoofspade OpenFOAM Running, Solving & CFD 4 December 17, 2013 07:32
v2f model - periodic boundaries - turbulent viscosity limited to viscosity ratio Davide_sd FLUENT 1 September 14, 2013 11:53
