July 11, 2016, 16:31 |
v2f turbulent model
hamide hayati
Rep Power: 10 |
hi all
i want to simulate turbulent flow in a 2D channel (2*40cm) by v2f model. i set it as follow: -i try to use fine mesh near the wall, (y+<=1) -B.C : velocity inlet, v=5 m/s , and define functions for v,k,epsilon and v2.(to be fully developed from beginning of channel) outFlow for end of the channel nosleep fo walls. -second order upwind to solve equations. but unfortunately i can't valid my results!!!!!! for example i can't find u+ vs y+ graph correctly!!! and also v'+ vs y+ and k+ vs y+ near the wall!!!!(1<y+<100) i don't know what the problem is!!!! is there any one help me to handle this problem. |
k-omega-SST model (OF 1.6) - turbulent flat plate | cboss | OpenFOAM Running, Solving & CFD | 25 | August 9, 2016 09:53 |
porous media turbulent model P-dL, I get the different results? is the model wrong? | hitchenxue | FLUENT | 0 | July 13, 2014 05:57 |
Use of laminar model for a turbulent flow | jcamilleri | Main CFD Forum | 1 | July 6, 2014 06:54 |
Error - simplefoam when running turbulent model | twoofspade | OpenFOAM Running, Solving & CFD | 4 | December 17, 2013 07:32 |
v2f model - periodic boundaries - turbulent viscosity limited to viscosity ratio | Davide_sd | FLUENT | 1 | September 14, 2013 11:53 |
