heat release by surface reaction on walls
Old   March 17, 2006, 16:31
Default heat release by surface reaction on walls
Marie-Anne
I am confused about which boundary conditions to choose for the wall where a surface reaction that releases heat takes place. If I choose constant temperature, then the fact that the wall should be heated is lost. If I choose zero heat flux, then it heats too much because it is considered as adiabatic. Thanks for any advice or previous experience on that.
Marie-Anne
Old   August 16, 2016, 11:20
vlg
villager is on a distinguished road
At least last 5 years FLUENT allows to set constant wall temperature (ot temperature profile), convection (with heat transfer coefficient for the virtual flow outside the wall), radiation (with properties of emissivity, etc.), mixed (convection + radiation). These all could be used if your reactor is not adiabatic (wall flux = 0).
villager is offline   Reply With Quote
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
Plotting Surface Reaction Rate Ryan FLUENT 0 February 12, 2003 14:47
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
about UDF,VOF, surface reaction Burley Wang FLUENT 10 March 13, 2000 07:08
