Moving Wall Condition on a Curved Wall
Old   August 24, 2016, 05:06
Red face Moving Wall Condition on a Curved Wall
david
qwe11rty22 is on a distinguished road
I want to apply a moving wall condition to a curved surface, simulating part of a curved belt in an airflow.
Can I do this with the moving wall boundary condition without using a UDF? Will the physics be correct?
Or will I have to create a UDF following the profile of the curve to define the directional vectors?
Cheers,
David
qwe11rty22 is offline   Reply With Quote
Old   August 24, 2016, 08:41
Paritosh Vasava
vasava will become famous soon enough
If you have that surface as wall then yes, you can do it without UDF.
vasava is offline   Reply With Quote
Old   August 24, 2016, 09:11
david
Thanks for the reply.
Do you know what values should be used for the directional vectors? All 0's?
Im a little confused, as they are in the x,y,z directions only, and a wall element on the curved wall will have, say, a constant x value, and varying y and z values.
David
Old   August 25, 2016, 01:45
Paritosh Vasava
There is also option for rotational motion. There you can input axis-origin and direction.
fluent, moving walls
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
Deformation of wall by temperature condition Jay FLUENT 0 April 14, 2007 18:06
