August 26, 2016, 12:54 |
Roughness effect
SHEIKH NASIRUDDIN
Rep Power: 12 |
Dear everybody,
I'm using Ansys 15.0 Fluent for the simulation of V-cone flow meter to estimate discharge coefficient. For validation of Fluent code,I have experimental data. In V-cone flow meter, cone element is installed co-axially at the center of a circular pipe with surface roughness height 1 mm as the pipe is very old with rust. I have produced boundary layer mesh on the pipe-wall and cone element surface and the first layer height is 0.06 mm with growth factor 1.2. In Fluent wall boundary,I have set 1 mm roughness height and roughness constant 0.5. After well converged solution (SST k-omega and RNG k-epsilon), I calculated discharge coefficient. But these values are very high(Cd=0.84 i.e. similar to smooth pipe Cd value) as compared to experiments data(Cd=0.71).It seems that surface roughness height is not effective in simulation. Can anybody help me, how to get roughness effect in simulation? Thanks in advance. Nasiruddin |
simulation of effect surface roughness on aifoil | kamyarmech | FLUENT | 1 | February 28, 2016 09:33 |
wall roughness effect on pressure drop | mactech001 | CFX | 16 | February 22, 2013 05:55 |
Effect of roughness on the results | rskrishna87 | CFX | 0 | June 15, 2011 04:49 |
Ideas for modelling effect of roughness on drag? | andy2O | CFX | 13 | January 18, 2009 18:30 |
Roughness effect | acc | FLUENT | 0 | April 23, 2004 01:47 |
